Vanner1993
I had serious running issues with the truck, finally got down to having to pull the heads. As I pulled the rocker arm rail off the driver side head, the #6 intake spring fell off. I found 1 of the retainers, hopefully the other is in the pan. After I pulled the heads, passenger seems ok but driver side had a bent valve. I figured ok, I will throw another valve in, pulled it out and there is 3 cracks around the valve area. So I will most likely get a head out of the junkers tomorrow and I will try to get an 88 and newer one if I can. Is the piston ok with that mark from the valve? Here's the pictures.
