ewwebb
- Dec 20, 2010
I've replaced the gas tank, the fuel line, the fuel pump and the carb. I went with the stock MotorCraft two barrel. My problems began with the truck dying for lack of fuel when driven cold and dying for lack of fuel when driven over Forty MPH when warm. That was even after I'd replaced everything except the carb. Whenever it would die just waiting a few minutes would allow it to be started right up again until the next instance. I replaced everything up to the carb and finally reasoned that it had to be some crap in the float bowl. Also my A.I.R. pumb went bad so I bypassed that by removing the pulley and putting on a shorter belt. After installing the new carb the truck runs fine after warm up, but won't idle until then. Now for what I consider to be the strangest problem. When driving on the highway the truck will starve out if I'm going into a headwind! Is the mechanical fuel pump not sufficient to supply the carb. It is one of the bigger two barrels that I've seen and my milage is crap. I get maybe Ten to the gallon. The truck is an '84 with the last of the normally aspirated engines, and a Five Speed tranny. Thanks for any help.
