Mustang Wheels
block007
Hey guys, just wanted to give a heads up. You can fit the Mustang wheels that are on Zmans truck in the tech section if you use a 1 inch spacer AS LONG AS THE TRUCK IS NOT LOWERED. I used the spacer, had to grind the studs off some, and they went right on. Could maybe get away with a 3/4 to 5/8 spacer if you did not want to go an inch but i think the center caps are close with the inch spacer. Hope to have some picks up asap of the wheels on the truck.:headbang:
