I used two of whichever side had the stud more in the center.
They worked ok, I had to shim one side about an inch and the other side a half an inch so I could get the rear drain plug out of the oil pan. It is common for 4x4's to run into clearance issues with the drain plug and TTB pivot bracket though.
For
