Mustang Booster and Master cylinder swap?
Yotaismygame
Oregon
I'm using cobra front mustang brakes and explorer rear disc setup on my current ranger project. Would the booster and master from a 2000 mustang swap over and would it be an upgrade? Maybe just the master? Searching I saw some mention using that setup but nothing about the swap or anything.
I see this got moved. Guess I was in the wrong spot. I was considering a 93 cobra master though since I'll be running the matching front calipers and eventually upgrading the rear too. But the bore size is 1" which is slightly smaller than the Ranger master. So bad idea? I plan to do a complete custom brake setup so maybe the stock master and booster will be fine with an adjustable prop valve.
i have a cobra brake setup with a Explorer disc brake differential the stock works fine.. but now thinking of putting the explorer booster with master cylinder. let me know what you do
I'm going to try the stock setup first. Right now with the build I have planned cobra front and rear brakes with all custom braided lines through out and a manual prop valve. It'll be awhile though. Currently waiting on the AJE front suspension kit and my 5.3l ls block is at the machine shop.
