Muscle Mig????
RangerNVS
Well I'm looking at getting a mig welder, and I think I can
get a really good deal on this, I've spent alot of money with
snappy, and me and our local dealer are pretty damn good
friends. So I've been eyeballing this for awhile, he had it on the
truck for a couple of weeks and then took it off. So I know he's
had it for awhile. I know these things aren't THAT easy to move,
hence why I think I could get a good deal on it. What do you guys
think? I've got some credit coming back to me that's why I'm looking
at this one...instead of having to pay all of it with cash, I could use
my tool gift cards...I know there is better ones, and probabley cheaper
ones. But what's your guys opinion of THIS one?Thanks for your opinions!:biggrin:
140 amp output @ 100% duty cycle, 120VAC, 50 Hz/60 Hz. Use for continuous, spot, or stitch welding using .023" through .035" wire. Welds up to 1/4" in a single pass. For use in auto body collision repair, automotive repair shops, maintenance and manufacturing applications and custom fabrication shops where voltage input is limited to 120V. Highest duty cycle 120V MIG welder available. Includes cylinder rack, MIG torch with 10' cable, 15' feeder cable and 20' power input cable. Offers spot and stitch weld capabilities. Two-year warranty (except MIG torch).
Additional Description:
Snap-on Muscle MIG welders weld continuous, spot or stitch all ferrous (steel, stainless steel) metals. Detachable feeder provides increased maneuverability and extended reach. Thin ferrous metals as well as copper can be welded with the optional TIG accessory kit. Each model is spool gun ready for welding aluminum with optional accessory. Each welder includes a flowmeter-regulator and parts kit. See SS2943 brochure for additonal information.
Additional Features:
Compare our welders. Common welders have 30% Duty Cycles, which means you can only weld three minutes out of ten at full load amperage setting. Snap-on welders feature 100% Duty Cycle – weld ten minutes out of ten at full load amperage setting. There Is A Difference™.
Product Specifications
Stock # MM140SL
Name Welder, "Muscle Mig" Wire Feed
Price** $2,995.00
Brand Snap-on
Country Of Origin USA
Input Voltage 120V
Input Current 20/30A
Output Current 30-140A
Duty Cycle 100% @ 140 Amps
Optional Aluminum Spool Gun MHG5B
Optional TIG Kit FLEXTIG12, 25
Maximum Thickness, inches 1/4"
Wire Size Range .023"-.035"
Shipping Weight, lbs. 198
Buy from a welding company like miller and the are cheaper and a whole lot better than what snap-on sell because really you are buying a cheaper welder and because it has snap-on on it you are going to pay top dollar!!!!!
It sounds like quite the machine, hope you don't want to carry it very far.
You could find a much bigger and better welder for less money than that.
also you don't need 100% duty cycle because i doubt anybody will be welding for hours and hours and never stop welding[/URL]
Excuse me, but i weld all day, all night, i weld in my sleep, i weld on the can, i weld while im eating, i weld while im on trs, i weld while im at school (seriously, basic arc) i weld when i working on my truck, i weld when im at work at fastfood, i weld when i go to autozone, ALWAYS :icon_welder: :icon_welder: :icon_welder: :icon_welder: :icon_welder: :icon_welder:
thanks for the opionions guys.....I'm looking at a Miller 212...seems to be a nice setup for less
oh sorry my bad !!!
Much better idea! And much more versatile.
The 212 is nice but take a good look at the 211 as well. It is more portable because of the smaller case but can still run with the 212.
its not hard to get 140 amps at 100% ANY 180A OR LARGER WILL PROBLY HAVE A a 100% duty cycle at 140a
