Bob Ayers
A lean code means the HEGO sensor output at the PCM reads less than 0.45V as the PCM commands a rich cycle. The HEGO sensors on many of these vehicles ground through the exhaust Y-pipe, through a ground strap, to the body (most -- and perhaps all -- of the OBD-I HEGO sensors are 3-wire types). The PCM has its own ground directly to the battery. If one of these corrodes, you get an extra voltage drop from that. This means the PCM thinks the HEGO sensor measurement is lower than it really is. If it's enough (and I've seen it), you get a lean code.
Mike, a high resistance ground on the O2 sensor will cause a voltage drop, which will increase the sensor output voltage making the PCM think it's richer than it actually is, not leaner........A high resistance in the PCM ground will have the opposite effect.
