- Oct 18, 2020
- Gig Harbor, WA
- 4.0 V6
- Automatic
About a month ago my 2008 Ranger started having issues with losing electrical power. Wipers slow, electric windows slow, then would not start. Uh oh, sounded like an alternator problem. Replaced with new 130A alternator (not rebuilt) and everything was fine.
About a month later started have brake problems like the ABS system not working right. When braking the truck jumps like brakes locking and released quickly. No warning lights. Sometimes the brake pedal feels mushy, but brake fluid is full. Figured there might be air in the system so planned on having the brakes bled.
Now, twice now, when I have to brake a little harder...
I lose power to a dash cam first. About 10 seconds later the ABS light comes on, then the Brake light, then I lose power to tach, speedometer, coolant temp, gas gauge, and all warning lights. Radio stays on and truck still runs. I hear a clicking sound from the fuse panel like relays clicking. Wipers and other things are still powered but clearly from the battery only.
This time after I turned off the ignition it will not start, just the solenoid clicking.
A bad alternator? I'm not sure. Wiring harness problem? I've looked as best I can and everything looks okay visually.
Any ideas would be appreciated.
