Moving axle forward... questions
koa's93ranger
Las Vegas
So im finally to the steering portion of my build. currently my dana44 is tacked in place at 5" forward from stock. im gonna be running high steer on my setup. i know 3" is the ideal limit for axle movement to work correctly. but ive seen some guys on here go as far as 7" with stock steering box placement.
my question is...what issues will i run into by having my axle 5" forward instead of 3". is steering gonna be affected or just front bumper clearance issues?
i would like to figure all this out before the final welding is done and have to figure out my issues the hard way and have to start over.
Anyone???
I know jester race had his at 4" and someone else did 7". but those are both broncos i believe
mine is at 4"....but steering at full stuff on driver's side with tire turned full passenger can make contact with diff cover....
l8r, John
l8r, John
but your running shackle forward right? so that makes a difference at full compression i would think. it would be more like 6" or 7" for you. thanks for the info
