Mount to transmission bolt size for 4R70W
JoshT
TRS Banner 2012-2015
Macon/Fort Valley, GA
GA - USA
Vehicle
Total Drop
few inches
~30"
Trying to finish up the transmission portion of my swap, which is mostly the mounting. I think I'm going to use the stock explorer mount and adapt the Ranger crossmember to work. I removed the mount for clearance when sliding the engine and trans into the bay, now I can't find the mount bolts.
So anyone happen to know the proper bolt size for the 4R70W trans mount to trans bolts?
It's a M12 x 1.75 about 30mm length. I've read it should be closer to 1" which is about 25 mm, but a 35 mm worked fine for me.
