icemilkcoffee
- Oct 14, 2009
When I first got the truck it would never even move past the C on the temp gauge. I replaced it with a new aftermarket thermostat and saw almost no improvement at all. Then I switched to a Motorcraft thermostat from the dealer (it's actually made for a newer model Ranger, and retrofitted to all earlier Rangers). The rubber seal has a groove in it, and there is a steel wire inside the groove. It works wonders. The truck instantly warms up. No more cardboard in front of the radiator!
Oh yeah- another thing I learned- use the factory gasket. The factory gasket's bolt holes are slightly too small to pass the bolts through. You have to screw the bolts in there such that the gasket captures the bolts. That way you don't have to be fumbling with 2 loose bolts while you're trying to line the t-stat housing up and keep the t-stat from falling off at the same time. That gasket probably saved a good 15 minutes of frustration.
