- May 19, 2009
- 1994 & 1983
- Automatic
Thanks for the response.
So he has the rods on the wrong side of each other? It's been a long time since I've been in side a motor. Even though he has the piston facing the right direction, can the rod slide along the wrist pin enough to place the crank end of the rod on the wrong side of the journal?
In any case I think he has to do a teardown and inspection.
I find myself in the same situations sometimes when I go too quick or have 'just enough' knowledge to be dangerous. That's why I like TRS, for the knowledge that I don't have yet.
Richard
The cylinder will line up with the side of the crank journal that the rod will go on and the wrist pin in the piston should be centered or close to it. If you stick rod #1 into cylinder #7 with the piston still facing the right way and the piston was hung on the rod to be in cylinder #1 then this would make the crank hard to turn as the bearing in the rod would be rideing on part of the Radii of that journal and the more that are installed wrong would make it harder and harder to turn the crank. If he finds this is his problem I would replace the bearings of the rods that were installed wrong as they have been squished onto the Radii and now have been changed in some manner to their proper size that they were made to be.
