Motor mounts for 2000 ranger 2wd coil spring setup
Lugosun
Virginia Beach
Just got a 2001 donor explorer and swapping everything into my 2000 ranger rwd with coil spring front end. Haven’t dived into it yet but what motor mounts will work? I’ve seen a few different answers online and most of the forums have stuff for 4x4 5.0 swap or torsion bar setup
Not sure what you need. But I looked, they made 2x4 and 4x4 versions of the 2001 explorer. With the 5.0 also. So that being said, I looked on rockauto and all 5.0 motor mounts are the same, 2x4 and 4x4 in the explorer. There is no designation and different part numbers for the different drivetrain setups in the explorer.
Hey thanks for lookin into that man. I finally found what I was needed. I need the 4.0 motor mounts and adapter plates as well so I’m gonna order em from Ricks Rangers
think 2wd ranger edge. sure its 2wd....but a 4x4 chassis. if the 2wd ranger is a true 2wd chassis it is a bit different.
i would go ls with that.
