Yes, but you will need to mount them to the block, drop the motor and trans in the engine bay, mark the holes, pull the motor, drill the holes and slot them vertically so the mounts can slide into place (or bolt them in before dropping the motor in, then drop the motor in to check if you drilled in the correct location. If you, you need to take note where you are off, pull the motor, modify/move your hole, then drop the motor in again...
SVT
