bmonee5
so i recently had new rings, 1 new piston, new valve guides, new main bearings, and all new gaskets put on my 1983 2.3L engine. So now about 900 miles after this minor rebuild i've started noticing a knock. It sounds like its coming from the lower end but i'm not 100 percent sure. People have told me it could be a valve that is out of adjustment which would be best case scenerio but wouldnt the valve tap at all rpm ranges? Right now it only seems to knock through certain rpm ranges of all 4 gears, and when i start it up and the choke is on you can hear it rattling. Anyone have any clue what this could be and is this going to require pulling my engine AGAIN?
