- Apr 13, 2008
- Fort Lauderdale
- State - Country
- FL - USA
- Drive
- 2WD
- 3.0 V6
- Tire Size
- P235/75R15
- My credo
- A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
Have just a narrow spit of grass 'tween my driveway and the neighbor's sprinkler system. His sprinks were jetting into my grille and headlights. It made my left headlight go dim, on both high and low beam.
It's a rental prop, absentee landlord, so I just adjusted his sprinklers myself, coincidentally giving myself more free watering of MY grass, and zero watering of my Ranger.
After enough LOW humidity wind blows into the nose of my truck, the headlight returns to normal brightness. This cycle has occurred several times.
After some recent wind-driven rain "taken on the nose", it's dim again.
Thinking about taking a hair/blow-dryer out there and seeing if I can make it bright again, and maybe localize where the moisture-sensitive or moisture-retaining fault is.
In the meantime, any ideas? I'd like some insights before I go pulling the battery (which is in the way), etc... it's a safety issue.
Thanks in advance.
Thanks in advance.
