- Feb 2, 2009
- Age
- 37
- Bemidji, MN
- Automatic
Since i have Da Beast back i want to work on making it a better running and more modern functioning. This will be a slow build up as it will take time to get the funds and the parts and of course the skills needed to make it all work.
one big thing in the bringing it to the moden times is of course the Engine Swap but that will be a big thing as i need to change alot of things to make it work.
I plan on running the 2.8 until it dies or is near death. i did want to do a TBI on the 2.8 but if i do the Swap im not sure if its worth it. Another thing is what engine, the 4.0 is the best candite as its the top of the tree in stock engines in RBVs V8s notwithstanding. im going to see if i can find a fellow member whos doing a V8 swap and wont be needing the pulled engine/tranny so that could net me a 4.0 or a 3.0.
im going to loose the dash interments and replace them with the aftermarket gauges in the place of the old ones set into a metal plate. or perhaps a dash swap.
im going to add more to this as i pull together the plans and thoughts. so stay tuned.
