mk42gunner
My 88 2.9 5sp 4x4 has a noticable miss under load in all gears, until the engine gets above 3,000 RPM's, then all cylinders start to fire and it is like hitting the go fast button on a nitrous system.
The problem is getting worse, sometimes it acts like it doesn't want to pull itslef when taking off from a stop.
I have a new TFI module and coil from unrelated problems. New fuel filters when I replaced the intank pump in July. When I hook up the scanner, there aren't any codes.
I put a can of Seafoam in the tank when I filled up a couple of days ago, thinking it might be clogged injectors.
Does this sound like a clogged cat?
Thanks for the advice,
Robert
Robert
