swcraig1
I have a 2000 Ford Ranger 3.0. A few months ago it started having #4 cylinder misfire. I tried replacing all the basic things plugs, wires, coil pack, fuel filter, crankshaft sensor, #4 injector. I took the truck to the garage, they said it had a burnt valve. They found a used head and replaced it. After picking the truck up and driving it about 30 miles cel came back on, showed #4 and #2 misfire. Took truck back to garage, they replaced the other head. After picking truck up about 30 miles cel came on again, #4 misfire. To try and make a long story short, the truck has been in and out of the garage now, more in than out, for about 2 months now. Finally got rid of the #4 misfire only after replacing both used heads with brand new heads. The other day when I picked the truck up for the last time, I was told by the mechanic that he could not figure out what was causing the misfires. He said the last time he drove the truck sitting in the parking lot idling it had a #2 misfire. During driving it, it came up a #5 misfire, and by the time he got back to the shop it came back up a #2 misfire. Luckily since they could not figure out what was wrong with the truck they refunded all my money. Here is a list of everything I know they changed or checked on the truck. They also replaced everything that I had changed before I originally took it to them, plugs, wires, etc.
both complete cylinder heads replaced
cam phaser replaced
cam sensor replaced
Injectors #2 and #4 replaced
coil pack replaced
plugs replaced
plug wires replaced
head gaskets replaced
intake gasket replaced
exhaust gaskets replaced
air filter replaced
fuel filter replaced
all O2 sensors checked
pressure on all cylinders around 145psi
valves water tested
air flow pressure from exhaust
converter temperature good, not overheating
fuel pressure good
fuel rail checked for blockage
timing checked
computer checked
timing on cam syncro checked
cam checked for ware
changed some vacuum hoses
Trying to see if there is anything else I can check myself before I take it to another garage. Any help would be greatly appreciated.
cam phaser replaced
cam sensor replaced
coil pack replaced
plugs replaced
plug wires replaced
air filter replaced
valves water tested
fuel pressure good
timing checked
computer checked
