locovaca
Just picked up a new to me 3.0 (93 with only 128k). The engine is in fairly good shape except some faint ticking and a slave cylinder on its way out.
One of the exhaust manifold bolts snapped off, or so it seems, by #3 cylinder. I'm thinking there's a leak there. So I'm going to try to pull the exhaust, rusty bolts be damned, to put some new manifolds on there. I'm also going to pull the intake so I can get the valve cover gaskets replaced as one side is leaking, and when I did them on my old Taurus I found it was way easier with the Intake off.
So pulling the Intake, pulling the Exhaust, pulling the valve covers... is there any reason I shouldn't just go ahead and replace the head gaskets while I'm in there? I haven't done any sort of compression/leakdown test, engine seems strong otherwise, so I doubt there is a need to do so, it just seems silly with having to do everything else not to take the extra step. Plus, from what I've read, it's alot easier to get broken off exhaust bolts out of the heads with them off the engine. I know I already have one, I'm sure I'll end up with more...
