Hi guys! Been lurking on TRS for a decade but this is my first post, not sure if post location is correct. I’m hoping someone can give me some advice. Current Ranger is an 02 edge, 4x4, 4.0, 5 speed MD05. 215k miles. It’s been my daily driver for almost 10 years. I recently had the rear main seal replaced. Since then I’ve developed a rattle/scraping sound that as far as I can tell by where the sound is coming from, is transmission related. It’s not crazy loud, at higher rpms the engine noise drowns it out. It’s loudest in 5th gear, then 3rd and 1st. 4th being the quietest followed by 2nd. Can still be heard in neutral but only when truck is in motion. No change when clutch is depressed but shifting from 5th to 4th basically cuts the noise in half. Hence my head scratching and advice searching. It sounds almost like a crunchy bearing but I can’t say 100%. Fluid is due for a change, about 50k since last time, but it’s full and doesn’t look terrible. Timing chains were done at 200k. I tried to get a recording of the sound but my phone won’t pick it up. Anyway, any advice from you fine gentlemen would be greatly appreciated.
