Mazda M5od-r1
RumpRangerSTX
Solid Axle Swap
mt holly nj
What Did They Come In And What Year And Model Had The Lowest Gears In It. Did They All Have The Same Gaers Thankz U .
I believe all the information relating to gear ratios in various transmissions and what they came in is in the tech library.
Can Put A 2wd Trans And Just Take The Tail Off And Put My T- Case On It Or No Not Realy Now If It Can Be Done Thanks
probably, depending on what t-case you have
maybe you should slow down when you type cause i could barely understand that, had to read it twice
No, the difference between the 2wd M5OD-R1 and the 4x4 is more
than simply the housing.
The output shaft is physically different.
What came with them?
Read the sticky at the top of this forum.
AD
