Mazda M5od-r1
RumpRangerSTX
mt holly nj
What Did They Come In And What Year And Model Had The Lowest Gears In It. Did They All Have The Same Gaers Thankz U .
I believe all the information relating to gear ratios in various transmissions and what they came in is in the tech library.
Can Put A 2wd Trans And Just Take The Tail Off And Put My T- Case On It Or No Not Realy Now If It Can Be Done Thanks
probably, depending on what t-case you have
maybe you should slow down when you type cause i could barely understand that, had to read it twice
No, the difference between the 2wd M5OD-R1 and the 4x4 is more
than simply the housing.
The output shaft is physically different.
What came with them?
Read the sticky at the top of this forum.
AD
