Max Tire Size...
Redneck Youth
i have a 1994 ford ranger xlt single cab 4x4, and im owondering what the biggest set of tires i can put on it and still be able to turn, i think its around 32" but im not sure, i just want to make sure before i start buying tires, the rim size is, 15 inch rim by 235mm tire, thanks for lookin
-__-
gee sorry to trouble you,i was in a hurry and needed some quick advice from somebody whos knows something, guess im out of luck
-__-
Probably faster to go to the proper forum section, look up that question and find answers that are already there than it is to post a brand new thread and wait for someone who knows the answer to stumble across it..probably hours later.
i have 31s on my 97 with no problem....i know i can fit 32s in the back. and maby in the front.....just try it
I had a '97, 31" tires fit no problem. I tried to fit 32" tires without lift and they rubbed (I'm not sure how much, the tire shop test fitted them and reported back that they didn't fit and put the 31s on before I could even look at how the 32s fit).
^^^what they said....search for it, Bro. You will be surprised about the Search Feature....so cool and neat and it works.....lol
31's on a 96 here light rubbing on that last half turn of the wheel. Otherwise works great!
i have 32's on 15x8's with only 3 3/8" back spacing so they are pushed out a bit. i have the same truck essentially but with 2" leveling coils from skyjacker. all i had to do was trim the fog valence a tad. i bet with stock wheels i could have cleared them with the coils but with out trimming. if you want a cheap lift look up the washer lift. or buy new coils (recommended. who knows how bad/saggy your coils are now)
