- Aug 7, 2007
- Costa Mesa, CA
- State - Country
- CA - USA
- Other
- 2004 Bronco Badlands
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Total Lift
- 1.5"
- Tire Size
- 33"
In another thread on A/C, I posted a question about being able to control temperature while in the Max A/C position. I want to do this because it recirculates the cabin air instead of bringing in outside air. This would help keep dust, smoke, foul odors, etc. from entering the cab without having to deal with the coldest air your A/C will put out while in Max A/C.
I decided to make a new thread on it in case anyone else is interested in doing this. Several suggestions were made and helped to lead me in the right direction. I was hoping a modification to the HVAC switch would be possible to make this happen without having to add any shut off or rerouting valves to the HVAC vacuum system.
I got out my Ford repair manual and studied the vacuum and electrical routing system. According to that manual, all the vent flaps and coolant to the heater core are controlled by vacuum. It appears the blend door is controlled manually with a cable system. Electrical only controls the HVAC fan.
In the Max A/C position a vacuum line sends full vacuum to the recirculate/outside air inlet motor which puts it in the recirculate position. That same vacuum line sends full vacuum to the heater coolant control valve which shuts off the (hot) coolant to the heater core. There is a tee in the line to send vacuum to each of those vacuum motors. So, it looks like there is no way to modify the HVAC switch to do what I want.
It looks like there are two choices. One is disconnect the vacuum line going to the heater coolant control valve after the tee and plug that vacuum line to prevent a vacuum leak. This means there would always be coolant flowing through the heater core but the blend door could be used to bypass the heater core to provide outside air in to direct non-heated air through the vents. This is the way it works in all positions any way other than Max A/C. The other way is to install a shut off valve in the vacuum line going to the heater coolant control valve after the tee. That way you could leave it open if you want the Max A/C to work normally or close it if you want to be able to control the temperature in Max A/C. I don't know how accessible this vacuum line is and it is possible an extension to this line would be needed to put that shut off valve in an accessible location.
I am presuming the temperature control switch to the blend door is still functional. It is supposed to be manual and I don't see how putting the HVAC switch in Max A/C would have any affect on it. Hopefully, next weekend I will have some time to get in there and test a few things to see if my idea works. I will update the results.
