Master Clutch Cyclinder Push Rod Removal
bernerboy
Michigan
1988
Evening everyone
I am in the process of changing the Slave Clutch cylinder and the Master Clutch Cylinder. I have the slave all done and now am working on the master.
But I can't get the Damn Push Rod out of the old one to get the clutch interlock disconnect.
What is the best and/or easiest way to remove the push rod that will not come out.
Thanks in advance for your assistance in the past, now and in the future.
Gene
:icon_cheers:
Took some doing and some PB Blaster but was finally able to physically force it out. What a pain. I figure it might be OEM as the Bronco II only has 92 k on the odometer.
Found that taking the fender well out helps in removing and replacing the Master Clutch cylinder.
Thanks
Gene
