- Nov 19, 2007
This procedure worked like a champ. Easy to do. I removed the shift boot, and the inner boot and pulled the plugs, cleaned the area and reinstalled all throught the shifter hole. I spent about 20 minutes total. No more leak. I used the red permatex gasket maker in a tube. Followed the instructions that were very good.
http://www.therangerstation.com/tech_library/shift_rail_plug_maintenance.htm
