Dave18
Okay, so I have finally made progress on my B3000 off road project... truck started as a manual 2wd with a worn transmission, so I've swapped in a remanufactured M5OD and added a manually shifted transfer case. Anyway I drove it for the first time today, and while low range works, when you shift from 2wd to 4hi, there is a rotary grinding noise and the t-case front output slowly rotates, as though it is not quite engaged (no front driveshaft as of yet). Notably, when you shift from 4low to 4hi through neutral, the 4hi seems to work normally. No weird sound or anything.
At first I assumed the shift linkage was misaligned, but I followed the adjustment steps (lining up the chamfered edge of the gate with the shifter shaft in 4low) and the problem persists. Could this be a fault in the transfer case? The unit is a remanufactured one from Zumbrota drivetrain.
