kostiuk
- Jan 4, 2015
I am replacing the clutch on my 06 4wd and I have all new parts, disc, pressure plate, throw out bearing/slave cylinder. The problem I'm having is the tranny is about an inch away from the engine block and the throw out bearing is hitting the pressure plate fingers. Now I'm not sure if this is normal and I should just try and get some bolts in it or I was thinking about cracking the bleeder screw on the slave cylinder and pushing it back some. I've never done a clutch like this one so I'm unsure of the best direction.
Any suggestions would be great.
Thanks, Kevin K.
Thanks, Kevin K.
