BDAB, it could be the clutch. But I would suspect it's the transmission / shift forks instead.
If the car is off, you should be able to manually push the gear shift into position (gear). You don't need a clutch to shift the transmission. If the shifter doesn't stay in position or pops out, there's your problem.
If the engine is off, the shifter is in 1st gear, and then the engine is started, the engine should move forward and able to drive normally. If it pops out again or you cannot hold the shifter in the position to hold the 1st gear, then your transmission needs a rebuild.
The internal slave only moves out the clutch fork (clutch shift fork), which slides the throwout bearing, which depresses the fingers of the pressure plate, and disengages the clutch.
If the engine is off, trans in gear, and you start the car (and it WANTS to move or starts to with the gear shifter in position), then you need a new clutch.
The clutch could just be worn and needs to be replaced (after all, think of it as sandpaper on the flywheel).
May I suggest Hayes HD clutch (from Jegs or Summit); it's excellent and has worked very well for me. Whatever you choose, get the entire kit and replace the entire clutch package. It's a system that works well together, and it's all new so that you don't have to do the tranny removal again later.
