I never extended mine, just left it.
how much body lift u got on it?
3 inch.
put a 3 1/2 inch in my fullsize, had to cut floorpan 2inches back and 2 1/2inches front of factory hole and had to tweak the shifter to get full engagement from 4hi-4lo and then i went to my local Shucks and got after market boot to properly cover hole. i realize you are probably running a borg-warner or somesuch for a transfer case, but my shift pattern front to back is: 4lojust installed my 3 inch body lift and had to cut my floor pan.if not my manual t/case would've been stuck in 4hi
2H
l
_4H
l
l_4Lo
Gotmudd, this is the shift pattern that BW1350 and 1354s have.
don't BW's have a nuetral position?
must be nice, wish my NP205 was like thatNot the 13-50 or the 13-54. But they kinda dont need one unless you have an auto. The oil pump in them allows them to be flat towed and still oil everything in the case.
wtf do i do to extend it?
and how do i remove the shift ball
