high5
- Aug 3, 2010
- Automatic
i have a '91 ranger with a 1354e and the shift motor just went out. i removed the motor and when i did i had an idea. how about a cable shifter to manually shift the electric shift transfer case. i think it could be done using the end housing on the shift motor and a cable that would rotate the gear wich rotates the shaft on the t-case. someone should make and sell these. i'd buy one. heck i might try and make one if i can find the time. anyway has anyone else made anything like this?
