sprkthead2
- Aug 1, 2008
- Automatic
Hello everyone, I'm new here.
My brother in law gave me his 1993 Ford Ranger STX with a 4.0 engine. The only prob so far is that would not engage in 4 wheel drive. Thanks to this website I believe I have fixed the electric shift motor. Now I have new problem:
When I go into 4 wheel drive I can feel it shift to 4 wheel but the car pulls to the right. Seems like only one of the automatic hubs are working. When I press the 4x4 button again to disengage I can still feel it pull to the right. If I stop and back it up to disengage the 4x4 then drive the truck drives straight. Reading through the forums I believe my conclusion is that only one of the front wheels is driving.
I now what to switch over to manual hubs to fix the issue. Question is according to Tech Library:
http://www.therangerstation.com/Magazine/May04/offroad.htm
Warn P/N 29071 has needle bearing while Warn P/N 37780 has copper bushings. But it also mentions that 29071 now may have the copper bushings.
"To my understanding, the current hubs sold under pt#29071 also use a copper bushing."
If this is the case I will go with 37780, if not then I will settle for 29071 because of the needle bearings. Has anyone who has done the manual hub conversion that has purchased 29071 can verify if it has the copper bushing or not? Advantage/disadvantage?
I've already ordered the spindle lock from 4wheelparts.com, by the way they are now 10.00 per wheel.
I'm going to order the hubs from here:
http://www.trsfabandoffroad.com/products/warnhubs.htm
Warn P/N 29071 - Manual locking hubs for 1990 - 1997 Ford Ranger and 1990-1994 Ford Explorer.
Warn P/N 37780 - Heavy Dana 35 Jeep hub that can be used as an upgrade for 1990 - Up Ford Rangers and 1990-1994 Ford Explorers with a Dana 35 front axle.
So once I have installed the manual hubs how do they work with the 4x4 push button? Is this correct:
1. With hubs engaged and 4x4 not pressed, this becomes a live axle? Just because the hubs are not engaged. This will perhaps waste 1 mpg gas.
2. With hubs engaged and 4x4 pressed, 4 wheel drive.
3. With hubs disengaged and 4x4 not pressed, this disengages the front axle which encreases fuel economy.
Please correct me if I'm wrong, I'm still a newbie truck owner.
