Manual hubs on a 2001+ Ranger
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS Banner 2012-2015
GMRS Radio License
TRS 25th Anniversary
Nocona
TX - USA
Other
2005 Jaguar XJ8
Vehicle
Drive
2.3 EcoBoost
3.5-inches
We have an article on swapping the later hubs and axles from a 2001+ Ranger on to a 1998-2000 Ranger to get rid of the vacuum hubs, and switch to a live axle:
http://www.therangerstation.com/tech_library/99hubswap.shtml
So in theory, shouldn't you be able to swap the 1998-2000 hubs and axles on to a 2001+ Ranger, and then buy the manual hub kit to have manual hubs on your 2001+ Ranger?
Anyone done it??
Perfectly doable, and even more pointless than it is possible. It costs hundreds of dollars, adds a failure point to each side, and saves almost nothing on fuel and wear. The estimated fuel cost of the live axle over the PVH setup was .2 MPG, that is the difference between head wind or tail wind.
But what if you wanted a locker, and didn't always want the front locked up with the live axle?
Scott told me he would not do it again. He said it wasn't worth the cost and effort. I was considering doing it before Scott did. After investigating what was needed to do it; the cost of it and having to use smaller bearings (potential failure point) prevented me from making the switch.
I would still like to have unlocking hubs. Recently my front driveshaft CV joint failed due to the rubber boot cracking and losing most of the lube. I think that was due to it spinning all the time. I ended up having to get a new front driveshaft and that wasn't cheap. I also drove my Ranger several weeks without the front driveshaft and could very much feel the improvement in acceleration. It was also smoother (less vibration) at freeway speeds and got noticeably better gas mileage around town. Gas mileage improvement on long trips was not noticeable. I think the main factor that prevents me from switching is having to go to smaller bearings.
How does a the cost of a selective locker compare with a lunchbox and all the conversion parts? I know they are pricey but all the conversion parts plus a lunchbox would have to come close to rivaling it. And (IMO) the ultimate fix would still be a SAS with real lockouts which costwise could still be in the running too.
From what I understand the manual hub kits are not overly strong, may not be the greatest with a locker anyway. Never been around them at all though.
gw33gp, they make disconnect kits to pull a truck behind a motor home, I wonder if it could be adapted to the front driveshaft :icon_confused:
And on the flipside, the u-joints in my D35 were stuck in one position because they never turned... so it kinda goes both ways. The driveshaft even has a detent in the pinion end u-joint from where it always sat.
