Manifold swap???
KYRangerDude
Whitley City
As reported in an earlier post,my manifold on my 2.9 has a small crack right where it bolts on near the #4 cylinder. After a failed attempt of JB welding, it burnt like I was told it would....and a failed attempt of high temp manifold repair gunk...it cracked.... I have found a manifold from a 4.0 and was wondering if it would fit? It looks the same but didn't want to take mine off a pure PITA that I"m not looking forward to, without knowing for sure if the one on the 4.0 would work.
It's the 4.0, a bigger engine, so not 100% sure, but more than likely it will not fit. Just go to your local junkyard. Mine has at least 10 rangers with 2.9's in them.
Highly doubt it'll fit. I believe the ports don't line up.
You'll have to grab one from one of us on TRS or the junkyard.
2.9l manifold
If you are talking about your exhaust manifold, P.M. me. I am pretty sure I have the cure.
