Use 1", and be sure to fill it with great stuff foam for rigidity. Id use a normal, off the shelf heat gun to get the bends you need. Some say grade 5 bolts are fine for mounting to the frame but I'd go Grade 8, it's not that much more expensive.
putting grade 8 hardware on anything you need to fill with foam for rigidity might be the textbook definition of polishing a turd
I am not sure, should I use 1" or 3" PVC? And should I use PVC Glue or screws in the couplings? What is the easiest way to heat and bend PVC without scorching them, or maybe just use 45 degree and 90 degree fittings? How would you do it?
reno said:I'm messing with ya guys!!!! I was at work and for some reason Stacey David's Purple Bronco came to mind,remember when he started to strip it down and got to the Roll Bars?? They had the pipe insulation on them? I started thinking, with twitches thread being locked about his seat in the bed and the welding rod in the mig so he could tig with the wrong gas.....well I just could not resist.......
