maamum
maamum
ohio
smoke coming from right under the spark plugs on my 94 ranger 4.0, its running a little warmer than usual. any idea what this could be?
do you have bad valve cover leaks?
how warm is it running gauge wise?
What color smoke and what does (if is does) if smell like. If you're running warmer that points twards a coolant leak that. The less pressure the coolant is under, the more easily it will boil over and/or overheat.
