M5od
Petemoss
I know in the wiring on the trans that one of the wiring plugs is for reverse lights but what is the other for on a m5od? Thanks
Sent from my SM-G530R4 using Tapatalk
Neutral position sensor.
However it should be pointed out that the "Neutral sense switch" should not be confused with the Neutral safety switch which is used on automatic transmissions.\
The neutral sense switch is more about idle strategy than anything else.
AD
Thank you. So if the neutral position sensor is not hooked up it can affect idle? Mine is not and it will idle very high when i start it.
