RICO9
07/2014 OTOTM Winner
OTOTM Winner
TRUCK INFO:
95 explorer sport
4.0L, M5OD
automatic 4x4, 1354
PROBLEM:
ok, this truck is hard to shift. it doesn't grind gears, it just needs to be forced into gear. this problem is in all gears. the resistance feels "plastic" if that makes any sense. the trans has fluid and the fluid is only about 10,000 miles old. I have had this problem for 2+ years. in the 2+ years the problem has not gotten any worse. there is no wierd noise or anything. clutch fluid is good and full. clutch peddal has good tension. (almost too much if you ask me). the clutch was replaced right before I bought it. (I have the receipt still). what is wrong with it? How do I fix it?
95 explorer sport
4.0L, M5OD
automatic 4x4, 1354
PROBLEM:
