vince87ranger
so i got my v8 swap all but done in my 87 ranger. 91 t-bird 5.0 with a e303 cam, dura spark dist, edelbrock intake and carb. then for the trans i have a 88 f150 m5od-r2 with a np205 t-case and new flywheel/clutch. my problem is my clutch wont fully disengage. it drags when coming to a stop, and cant shift. im fairly certian i have the clutch system fully bled out, and have full travel at my master cyl. looking through the bellhousing i can see my throwout bearing traveling about a half inch.
im using my rangers factory 87 master cyl, and the 88 f150's slave cyl. i looked up the part numbers and the fm146 shares the same bolt on slave cylinder as the m50d.
what can i be missing to not have my clutch disengage fully? do i need to adapt in a f150 master cyl? or was my new, but stock replacment clutch made to incorect tolerances? any advice from others that have adapted in a m5od-r2 please shoot me some advice! thanks!
