84stealthranger
ok my tk 4 speed is about to blow apart wont go in to 2nd gear. i kno what tranny i need im gonna get a m5od and im gonna put a 4.0 clutch and flywheel on so ill need a clutch kit, starter, block plate or mod mine to work and master and slave cylinder. my question is am i gonna have to make my front drive shaft longer or shorter or will it have enough slide in it to work. and the rear drive shaft will it work or do i need it to? if i was to swap in a dana 35 i kno its longer, if i did it all at once would there be any modding the front shaft? thanks in advance
