- Oct 31, 2018
- Dirtman's Basement
- My credo
- Give 'yer balls a tug. Fight me.
Could just convert it to EPAS....
That sounds expensive and more complicated than just replacing the pump doesn't it? I mean I know the new pump is probably going to whine, what kind of money and work are we talking here?Could just convert it to EPAS....
No way am I putting 1500 in a ford ranger, I love my truck, and if I could get an extra 500 hp out of that pump, I would. But noThe EPAS kit in Summit is about $1500, my pump doesn't whine that bad.
Pressure side hose brand new is like $20, and what is a JY out of a volvo?My EPAS conversion was $145 or so - 45 for the pump at the JY out of a Volvo, and $100 for the pressure side hose ?
Yeah I think I'll just replace the pump, thanks though.JY=junkyard
Volvo EPAS Conversion
After the Trail Ride, I realized with the encouragement of @AgPete139 , @Jim Oaks and @bobbywalter that I really need to get this article finished. Posting the incomplete version for review. Want to get it finished up over the next few days. AgPete and @lil_Blue_Ford drove it. They can report...www.therangerstation.com
I ended up draining the merconV and using 75w90 synthetic gear lube...............That was almost 1000miles ago
If you don't mind me asking, how much did you end up paying for a rebuild?I tried using engine oil. 5w-30 full synthetic worked really well one one high mileage M5OD I had - it shifted FAR smoother and completely eliminated a grinding 1-2 shift. I tried it in other M5ODs I've had over the years and it was no better and no worse. It's just something to try... if you're not having issues with the trans, there's probably no reason to do it.
I will say this, I drained million year old ATF out of one of them, which looked like black sludge. I filled it with engine oil, ran it probably 20k, drained it and pulled the trans for a rebuild... it was sparkling clean inside.
There was rumor some time ago about full synthetic motor oil, some very light weight variety being used. No idea though. @Dirtman knows a lot about it IIRC.
