M5OD in !st gen... what master/lines?
kunar
⭐Supporting Member
Toledo
OH - USA
Vehicle
Drive
im (hopefully) swapping a m5od into my truck sometime in the near future and i need to know what master and hydraulic line do i use? it kinda looks like i take the line apart from the master and use the m5od slave and line with the stock master?
The FM145 has a different slave connection, it's higher up, the 146 and the M50D both have the connection on the side (same slave for both trannys). I would use the stock master and the M50D/FM146 line.
you need a 1990 master, line, and slave.
okay, ive got an '87 fm145 master and a '93 m50d line and slave, will these fit hahns? i had thought about buying a new slave but i dont want to buy a master and line if i dont need to. thanks
edit: i also have the '93 master but it wont fit my firewall, will it?
i may be able to get my hands on a 2nd gen master and line but i dont know what trans its from.... will this help me at all? can i buy a slave for a 2nd gen m50d to fit the master and line that will still fit the trans?
