e30dirty
- May 15, 2011
- 87'
- Automatic
trucks an 87 b2, FI 2.9 had a a4ld that i broke the case on. Swapped in a junk yard m5od and and having some issues. Installed new slave/master reused line. bled well, no air, decent pressure. Start it up wont shift into gear just grinds to hell! repeated bleed (more than once) 2xchecked everything. still no go. opened up the view hole (large rubber grommet on bell housing) slaves not moving. something is ****ed up along the way, or?? I used a clutch kit for 87 b2 because its all the same right? Or is the 4.0 larger?? any help would be appreciated
