Junk Collector
Truck of Month
I will preface this discussion by stating that I rebuilt the trans in question, I have successfully rebuilt several others and have had a bunch of them apart and am looking for some experienced guidance on how to proceed.
This is all in a 1992 Explorer and the goal was to get a trans with lower 1, 2, 3rd gears. My build consisted of a 1994 4.0 M5OD case, 1988 2.3 tailshaft/1/2/3 gears, 1997 5th/reverse cluster, new input and countershafts to match the 2.3L components, a bearing and syncro kit obtained from Allstate Gear, and a top shifter housing from the 1988 2.3L trans.
I inspected everything as well as my fairly untrained eyes could throughout the build process and replaced anything that looked worn. Everything on the main shaft looked to be in good condition and the build process was pretty smooth. I used the shifter housing from the older trans because the shift forks were in good shape and it has the neutral switch, which my Explorer also has.
I put roughly 2000 miles on the trans with zero issues other than 4th gear being slightly hard to engage right out of the box, which I attributed to break-in and it has since been much better. However during my Utah trip last week, I was going up a small hill on a dirt road in 2nd gear, 2wd and it popped out of gear. I initially figured I was just lugging it too hard but the next day it happened again in 1st, 2wd. Frustrating. I wheeled all of Hell's Revenge and another ~500 miles of dirt and highway and had zero issues until a steep dirt road where it again popped out twice in 1st, 2wd. After that it has been much worse... even on the street pulling away from stop lights it will pop out of first. I will note that it has never happened in 4 Low (I'm assuming the gear reduction takes some load off whatever is happening in the trans.)
Looking for some guidance on what to look for - I will for sure check the 1/2 shift collar, IIRC that one is directional but I'm 99.99999% sure it's oriented correctly since I marked it as the donor was disassembled. 1/2 shift fork is a possibility but it looked fine, just some light scuffing was all. I read another thread that I can't find now where someone mentioned shimming the countershaft tighter fixed a similar issue. Seems to me that I had to shim it a hair loose.
@adsm08 - you were having this issue with yours right?
@PlumCrazy
@AllanD
@Transman304
@bobbywalter
@BlackBII
@PlumCrazy
@AllanD
@Transman304
@bobbywalter
@BlackBII
