m5od 2wd and 4wd difference
parkrangerjeremy
Solid Axle Swap
largo, Fl
i was wondering what the difference between the 2wd and 4wd m5OD tranny's? are the output shafts the same length and the only difference is the extension housings or are the output shafts completely different?
The only difference in the output shaft and the tail housing. The output shaft is longer.
