t_dickie
So here's the backstory. I've got a 92 4.0 4x4, with a bad bearing somewhere in my M50D. I think its on the input shaft somewhere, as the sound is related to engine speed, not road speed, and exists sitting in neutral. However that's neither here nor there, I KNOW the transmission is on borrowed time.
I gather that the M50D-R1HD was available after the introduction of the SOHC 4.0. My question is whether the newer, M50D-R1HD will bolt up to my OHV 4.0? Will it bolt up to the BW 1354 transfer case? Would I encounter any problems if I did the swap? If everything turns out to work, is it worth the swap, or should I just find a regular old M50D?
