Tractor Dan
94 Ranger XLT super cab
3.0 engine
2 wheel drive
So here is what is going on. It shifts fine going up through the gears. However when i push the clutch in it revs really high. I don't have a tach on the truck, it came stock without one. As soon as i let the clutch out or shift to a higher gear and let the clutch out i'm fine. It only does this with the clutch in. If i try to down shift it does no good, the thing still revs up and i gotta push the clutch in and fight it with the brakes to get it stopped.
So recap of the issues.
1. Revs high when clutch is pushed in
2. Fine when clutch is let out
3. Fine when clutch is let out after shifting to another gear
4. Downshifting does no good as it just continues reving
Any ideas what could be going on? I'm new to working on manual transmissions. I have only had automatics except for a 93 Topaz i owned for a short time but never had to do anything trans related.
I don't know if this could somehow play into it but the truck has a severe oil consumption issue. I'm keeping the engine topped off with oil and end of this week into next it's getting looked at and figured out. I have a feeling it's rings or valve guides but can't be sure right now. I'll try and answer any questions the best i can, as i said manuals are a new field for me.
3.0 engine
2 wheel drive
