I have a 94 B4000 (4.0l V6) with 5sp manual tranny, 4x4. It is fairly new to me and when I got it, the PO had just had a new clutch put in (with slave cyl). I beleive it has an M5OD tranny.
It has been running very well, with one problem: every so often there will be a bearing noise (squeal) from the tranny area (or perhaps the clutch or xfer case). It is not always there, and seems to be worse in cool weather and when driving uphill and when rpms are over 2500.
I checked the tranny fluid and when I got it, it was way overfilled??? (perhaps the PO was trying to cover up this tranny noise). Anyway I drained and flushed the tranny and refilled with new Mercon atf and a bit of some BG tranny additive.
I've tried some "experimenting" when the noise is present to try and isolate it, but it has not been that consistent. Just pushing in the clutch does NOT change the noise. If you hold the clutch in (in neutral) for a bit but still roll along at speed the noise slows then stops (front input shaft?). Sometimes if you let up on the clutch as that point all remains quiet, sometimes not. I've tried shifting into 4th, and again sometimes that eliminates the noise, sometimes not; however that may be more due to rpms going down than it being that center shaft bearing.
I've done some some reading on this topic, and it seems that the front input shaft bearing and mid shaft bearings are the likely culprits. But I suppose it might be a badly installed throwout or clutch. Pilot bearing seems unlikely as the noise usually starts when in gear clutch out and no motion at the pilot.
I'd like to nail down what is causing the noise. If anyone can ID this from my descriptions, please let me know. If there are some tests I can do to nail it down please let me know about them.
Also, I am hoping that since most of the time this noise isn't there, perhaps some change in lube might improve or fix the noise. A more or less viscous fluid maybe? (I once had the ford tranny mechanic at the local ford dealer tell me to put 5-30 in my f250 tranny to quiet it down) Again, any suggestions here are welcome.
Other than this intermittent noise the tranny is great, smooth shifts up and down, no popping out of gear and no obvious leaks, so I don't think I need to replace/rebuild it, other than for this bearing noise. Do people just replace the input shaft bearing?
Thoughts/comments?
TIA
Thoughts/comments?
TIA
