lucas upper cylinder & injector cleaner
broussard91
iowa,la
if it cant hang it cant stay
Ive herd guys runnin sea foam through the break booster vaccume line any imput on what lucas would do i tried it out seems to run better but will the cloud of white smoke go away
Hopefully it will go away.
Either fluid is fine.
I am not a fan of that method though, the upside is so small compared to the downside.
Downside being a bent connecting rod or broken piston from a hydrolock.
Just run it in the gas tank, same results, PLUS cleans fuel lines and inside injectors, just takes a little longer on the carbon build up, and no downside
You go easy on the stuff so you don't hydrolock it... I run sea foam all 3 ways. Tank, intake, and crank case.
Yeah gotta take it easy so you don't hydrolock if you follow directions it goes away after a mile or two ran through my bII as well as my dodge saw big difference in my truck though
Well ran half a bottle through didn't realize there's that much suction on that line bit it cleared up still having issues with my motor hit and missing
